I'm new here, and I know this would be the best place to ask.
So far, I have everything assembled in this rebuild, but the only problem I have come across is the piston rods and caps.
The Haynes manual says specifically for the 5sfe engine, that the rods need to be torqued to 18 ft lbs, THEN turned an additional 90* to be torqued properly. Well, needless to say, I did that. The crank would not turn, it refused. I loosened the rod caps, and the crank spun freely. So I torqued them back do to 18 ft lbs again. The crank turned, pretty easily. I torqued to a little less than 90*s, and it wouldn't turn again.
The plasti-guage showed fine. Am I doing something wrong here? or is it supposed to be that tight?? I couldn't turn it to save my life. It just wasn't happening. I appreciate you reading, and any advice or help that is given, I will greatly appreciate as well!
