distributor mounting bolt length - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2011, 06:54 PM   #1 (permalink)
View bumperbozo's Photo Gallery
hey, how long should the bolts be that mount the distributor to the (non-california) 5sfe? I'm putting my car back together (finally) and the only bolts from my pile that fit are one that is too long, and two that are only a couple threads longer than the width of the distributor flange. simplest conclusion is that the latter are the bolts that were there, but does that seem right?
1995 Celica GT convertible
2.2L 5sfe engine
bumperbozo is offline   Reply With Quote
Old 08-07-2011, 06:58 PM   #2 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $615531
View Zembonez's Photo Gallery
I don't know the spec, but I would believe that the bolts should at least be 1/4 inch longer than the flange is wide in order to secure it correctly. Any chance "those" bolts got used somewhere else by mistake?
Zembonez is offline   Reply With Quote
Old 08-07-2011, 07:08 PM   #3 (permalink)
damn. i dunno. the garage is kind of a mess despite my best retroactive organizational efforts. I thought I had all the bolts accounted for, but I don't see a better match length anywhere. and at the moment i can't think of anything else that I need to reinstall that takes M8 bolts (which is what I think this size is). I wish there were somewhere i could find all the bolt specs for the vehicle.
2.2L 5sfe engine
Old 08-07-2011, 07:44 PM   #4 (permalink)
you know, they might be about a 1/4 inch longer, but no longer than that. the holes go much deeper
2.2L 5sfe engine
Old 08-09-2011, 01:04 AM   #5 (permalink)
just fiddled with it some more. the two shorter bolts actually hold the throttle and kick down cables to the throttle body.
do you guys have cap screws or flange bolts on the dizzy, or one of each?
update:
went to ace hardware and picked up some class 8.8 M8x1.25x30mm cap screws and washers. perfect fit and i think less likely to throw the timing off as i tighten them.
2.2L 5sfe engine
