90 Toyota Celica 5sfe Oil leaking out of the top of motor oil dipstick - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2011, 05:30 PM   #1 (permalink)
View yadpwns's Photo Gallery
Gen5 90 Toyota Celica 5sfe Oil leaking out of the top of motor oil dipstick
Hello fellow Celica owners, I recently started having this problem . I was driving back home from work and I happen to notice smoke. Oil is coming out of the top of the dipstick hole not the bottom o ring. It seems the crank is building too much pressure . It's a 1990 5sfe so it does not have a pcv valve,ithasa pcv system which isbasically a hosefrom the valve coverto thethrottle body. Anyone possibly has had this problem before? I would love anytype of insight on this . Im really hoping it is not excessive blow by . This does not happen initially when I turn the car on from a cold start. I turn it on leave it at idle for a while and even rev it up and hold it high. It starts to leak after about a 2 mile drive and the car is at running temperature. I removed the hose on the valve cover when the car was at idle and a good amount if air blows out when at idle now when I rev the car up the air blowing out drops some. I've never had this issue before and it just started happening and I have no past experience with this type of issue so any help would be greatly appreciated. Thanks in advance!
yadpwns is offline   Reply With Quote
Old 08-19-2011, 09:26 PM   #2 (permalink)
Gen5 Here is a video of the oil spitting out
