bad vsv affecting idle speed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2011, 02:17 PM   #1 (permalink)
View bumperbozo's Photo Gallery
could a bad vsv be affecting my idle speed? i'm wanting to adjust idle as per the maintenance schedule and i don't know if i should wait until after i replace what appears to be a bad VSV. also, does anyone know where on the top part of the wiring harness i can connect an ohmmeter so it runs to the VSV so i don't have to get back in that tight area?
1995 Celica GT convertible
2.2L 5sfe engine
bumperbozo is offline   Reply With Quote
Old 08-24-2011, 03:30 PM   #2 (permalink)
Gameroom cash: $147537
I don't think you can't adjust idle. 92+ 5S-FE don't even have the idle adjust screw on throttle body.
Try cleaning inside the throttle body. Idle is controlled by ICV below the TB and it'll get gunk buildup.
Old 08-24-2011, 05:12 PM   #3 (permalink)
you sure? cause it looks like that little hole there has a notch where a small flat head screw driver would fit:
2.2L 5sfe engine
Old 08-25-2011, 10:16 PM   #4 (permalink)
From your photo I'm 100% sure. Its the pilot hole for the tube beside it. Idle screw is much bigger which take regular flat driver.
Clean the ICV.. ECU use it to control idle speed completely, no manual adjustment.
Old 08-25-2011, 10:19 PM   #5 (permalink)
pilot hole? what function does it serve?
i saw that sticky where the guy pulled off his IACV and totally overhauled it, but i'd like to know if there is a quickie way to do it in-situ, without pulling it off.
2.2L 5sfe engine
Old 08-29-2011, 04:47 PM   #6 (permalink)
Some TB need the extra air tube. The pilot hole for factory to locate and drill the hole through.
Get a can of throttle cleaner spray. Remove plastic intake pipe on TB. You'll see some holes inside at the bottom. Clean them out. Spray cleaner into the hole, let it seat for a minute. Spray some more in there. Repeat until it doesn't come out black anymore.
Old 08-29-2011, 04:55 PM   #7 (permalink)
you're indispensable.
"come out black"...where does it come out? do you mean out of the hose barb beneath the IACV?
2.2L 5sfe engine
Old 08-29-2011, 05:44 PM   #8 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
No, back out of the hole in the throttle body that you sprayed into. Let dry as long as possible before driving, I didn't dry out the system enough before I went for a drive and my celica suddenly decided it wanted to idle at 4000 rpm.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 08-29-2011, 06:19 PM   #9 (permalink)
so this will pretty much be a quick fix in lieu of the IACV overhaul?
2.2L 5sfe engine
Old 08-29-2011, 06:26 PM   #10 (permalink)
wait, that vacuum hose underneath the IACV probably doesn't like TB cleaner - it's hard on rubber/plastic, right?
2.2L 5sfe engine
Old 08-30-2011, 12:17 AM   #11 (permalink)
TB cleaner is ok on rubber.
The hose are coolant hose, so whatever you spray won't go in there anyway.
