The 5SFE is notorious for having a bad idle due to the Idle Air Control Valve. Pick up some Seafoam deep creep (some recommend any throttle body cleaner, but not all are safe for plastic coated parts, and the seafoam seems to work well), remove the air intake hose from the throttle body, just inside before the butterfly, there is a hole in the bottom of the throttle body, this passageway leads to the idle air control valve, spray some cleaner down in that hole, repeat a few times, and while you're at it clean the butterfly and rest of the throttle body. Let it dry completely, then reassemble everything. This seems to work for most owners.
'11 Kawasaki Ninja 250R, '12 Mazda2
