anyone change the horn??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2004, 11:33 PM   #1 (permalink)
Gameroom cash: $102920
View 90celica's Photo Gallery
mine is broken... where is it located???
i have a 1990 celica gts
90celica is offline   Reply With Quote
Old 05-25-2004, 06:11 AM   #2 (permalink)
GT-i Crew
lcarocha's Avatar
View lcarocha's Photo Gallery
Right next to the driver side headlamp. Just remove the plastic cover between the headlights and you will see Air Con filter/dryer (cilindrical metal thngy with the lens on top) and next to it the horns.
Luis C.
92 Celica GT-i (ST182)
2nd Gen 3S-GE
Caracas, Venezuela
http://www.cardomain.com/id/luis_c
lcarocha is offline   Reply With Quote
Old 05-30-2004, 10:24 AM   #3 (permalink)
View jdmac44's Photo Gallery
I'd put an air horn in
Josh
Champaign, IL
1993 Celica GT - First Love
1990 Celica All-Trac - Mistress ;o)
jdmac44 is offline   Reply With Quote
Old 06-07-2004, 10:14 PM   #4 (permalink)
4A-GE's Avatar
View 4A-GE's Photo Gallery
i have a 2nd Gen Camry horn... you can come pick it up for free.. or i can help you install it.. just 1 min or 2... very easy... one bolt then plug and play...
PM me if you want me to help ya..!!
4A-GE is offline   Reply With Quote
Old 08-19-2004, 06:48 PM   #5 (permalink)
View screamingdan's Photo Gallery
horn
4A-GE nice set of horns rollin in your post
Dan
screamingdan is offline   Reply With Quote
Old 11-28-2004, 09:26 PM   #6 (permalink)
View jamas's Photo Gallery
Canada Horn shit the bed
Did you solve your horn issue? I ask because I am also having horn issues with my tacoma. Turns out mine might be related to a spiral cable. Ever heard of this?
James
jamas is offline   Reply With Quote
Old 11-28-2004, 09:59 PM   #7 (permalink)
View canadiancelica's Photo Gallery
The wire has probobly rusted off or the bolt(s) have come loose, therefore breaking the circuit, as the bolts act as the ground. There should be only 1 wire that spilts to go to both horns. I know mine rusted off and all I had to do was put a new wire in, solder it all togther, tape it, and bolt it back in (clean the surface where the bolt meets the metal) and viola, beep beep.
John
canadiancelica is offline   Reply With Quote
Old 11-29-2004, 11:59 AM   #8 (permalink)
i never got mine fixed... i tried putting in a new horn .... but i the new horn didn't work..... so it must be a broken connection somewhere............... i will probably install an air horn or a horn that plays a nice tune....
in the spring......
good luck
1990 Celica GT - work in progress
1994 Tercel
Old 12-01-2004, 03:29 PM   #9 (permalink)
View slvrblt's Photo Gallery
jamas the spiral cable is the unit in the stearing colom that allows the steering wheel to be truned and still keep the electrical conection. I had to get mine changed but I don't remember how much it cost
slvrblt is offline   Reply With Quote
