Thanks alltracman78!
I have to admit, I am in uncharted waters here but am more than willing to give it a try. I need to fing the location of the ECU and how to get to it to do the test. Also, I need to find the wiring diagram(s) to tell me the location of the W pin. I have been searching the internet all morning.
FYI, I did have to replace a blown MIL light bulb (is was broken in half when I removed the bulb holder). As a check and before I posted my original thread, I replaced the MIL bulb and then switched it with Trans O/D bulb from just above the MIL bulb. The O/D light has always worked. I reconnected the console and turned the key to the on position. I hit the O/D button on the gear shift and the O/D light lit up. The MIL still did not light up. Maybe usless info here but I just wanted to make sure that it was not a bulb issue.
I hope that the problem is not the ECU. If my research is correct, the ECU is a pretty expensive part to replace (toyodiy.com, computer, engine control, Part #89661 $1,733.00). The circuit board is less expensive by far. The ECU looks like it is located in the center console above the transmission shifter under the radio.(?) I'll look through my Haynes Manual for a wiring diagram.
Finished the rear brakes and struts over the weekend (1st time for everything). Also have to tackle a broken washer fluid hose somewhere in the passenger front wheel well..can't get to it from under the hood.
Thanks again for all of your help.
