cant seem to program keyless remote :( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2011, 10:58 PM   #1 (permalink)
View tonkaforce's Photo Gallery
i have been trying for an hour an cant seem to program my keyless remote for my 2000 toyota celica GT. ive been trying for hours, but the car will not go into program mode and do the lock an unlock by itself after i do everything. is there maybe a fuse or something i should check would could possible be preventing my car to go into program mode? thanks
i ve been using these instructions
1) Getting a Replacement Remote
Look on eBay or Google, make sure the remote has the following FCC-ID: bab237131-056
2) Installing the remote (credit to iPal)
1 open door, take key out...
2 insert and remove key from ignition 2 times
3 close and open driver's door 2 times
4 insert and remove key from ignition
5 close and open driver's door 2 times
6 insert key into ignition
7 close door
8 turn ignition from 'lock' to 'on' and back to 'lock'
if you do step #8
*1 time it's for add mode
*2 times for rewrite mode
*3 times for confirmation mode
*4 times for prohibition mode
9 remove key
10 then door lock will cycle 'lock' and 'unlock' a number of times
corresponding to your key cycles in step #8
11 press lock and unlock button together for 1 ~ 1.5 sec then release
12 then within 3 sec press lock button for 1 sec then release
13 if you did correctly door lock will cycle once...
AND THIS YOUTUBE VIDEO
tonkaforce is offline   Reply With Quote
Old 09-21-2011, 07:51 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
your owners manual may outline the steps, otherwise check out a 7th generation celica forum like newcelica.org for a how-to specific to that car.
Bitter is online now   Reply With Quote
Old 09-21-2011, 02:13 PM   #3 (permalink)
yeah i jus went through the entire thing, check any possible fuses, and i found nothing. but it hit me thinkin maybe its because i removed the factory radio an put in a after market radio, would that have anything to do with it? please help , thx
