The only hitch that you may find is breaking loose the old nuts. Many years and many heat cycles tend to seize the nut to the exhaust stud. I was able to remove mine without really any hassle at all by soaking them in a penetration oil (pb blaster or liquid wrench), leaving it over night, soaking them again the next morning, warming up the engine some, soaking them again, and then I tried removing them. If they dont move after this, then you may have to take a torch to them, or try heating the engine up and removing them while still very hot. Breaking an exhaust stud is not fun.
Also you will have to get underneath but just to unbolt the old manifold from the downpipe and then later to reattach. Soak these bolts as well, as I've had one shear on me before.
'11 Kawasaki Ninja 250R, '12 Mazda2
