no headlights, charging, or any of the gauges r working.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2011, 08:46 PM   #1 (permalink)
View Leo00893's Photo Gallery
i need help i have a 2000 celica 5 speed just did the trans and the cables on it one of the cables was broken when i bought the car..well and the only way i could get to the cables was by removing all the wire harness in the inside of the car in the center ..well after i put everything back the alternator headlights and gauges stopped working,ive been killing my self wit taking everthing out and putting it back all the fuses r ok none r blown,now when when i turn my car in the on position the battery light doesnt go on it goes on but goes off right away.. its suppose to stay on now when i take off the AM2 fuse it stays on wit no problem.. also comes on when i disconnect the harness that goes straight to the ecm.. or pcm.. i checked all the grounds they r all good..please help somebody if u kno something about this give me something...i would really appreciate it.
Leo00893 is offline   Reply With Quote
Old 10-01-2011, 04:45 PM   #2 (permalink)
View zfjohnson07's Photo Gallery
I'd say check your wire harness, my 97 was doing the same thing and i realized i wired the wrong wires
zfjohnson07 is offline   Reply With Quote
Old 10-01-2011, 10:10 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
You will need a wire diagram to put it back together.
The Jedi Speeder at CarDomain
Old 10-01-2011, 11:02 PM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $559100
View Bitter's Photo Gallery
multi-fuse?
Bitter is online now   Reply With Quote
Old 10-03-2011, 07:12 PM   #5 (permalink)
ok guys heres what i found there is a short some where just dont know where i went mack to the inside of the car and found that the 7.5 fuse and a radio fuse are wat is causing this problem i need help i took off the fuse to the radio (the test light to the battery that i connected from the negative post to the negative terminal) and the light went off.. i took out the tail relay out because its just going on all the time i can hear it click constantly...i also took out the 7.5 fuse which controls all the interior light radio etc. i dont really know much about electrical problems but please help me...
