replace driver side transmission oil seal...remove driveaxle? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-11-2011, 02:55 AM   #1 (permalink)
View bumperbozo's Photo Gallery
i have to replace the driver side transmission oil seal. do i have to remove the driveaxle from the knuckle, or can i just disconnect the control arm, pull the knuckle to drag the shaft out a little bit from the tranny and get to the seal?
thanks!
1995 Celica GT convertible
2.2L 5sfe engine
bumperbozo is offline   Reply With Quote
Old 10-11-2011, 07:21 AM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Popping the axle from the trans is usually the hardest part. I dont see any way where you would be able to swing the hub out far enough to remove the axle from the transmission with the axle still in the hub. Also, the extra weight would be trying to push the axle back into the transmission.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
The Following User Says Thank You to RobMilkshakes For This Useful Post:
bumperbozo (10-11-2011)
