Check your MAF sensor. You can test your clutch as well using this method.
1 - Park your car in an empty parking space
2 - While the car is at idle, put the car in 5th gear (overdrive)
3 - Start letting go of the clutch and give a little gas
4 - If the car bucks and stalls, your clutch is fine and strong
5 - If the car starts rolling in 5th gear, the clutch is toast and needs to be replaced.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
