5sfe heater hose ID - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-23-2011, 10:53 PM   #1 (permalink)
View bumperbozo's Photo Gallery
5sfe heater hose ID
there's those two heater hoses that are right under the exhaust manifold that attach where the oil filter attaches. what are they for? what is their inside diameter supposed to be? i got some 5/8" on the recommendation of this impatient gates tech support rep, but the hose slides on pretty easy and the OD of the barb measures .610" (less than 5/8". the metal tube that comes down from the bypass pipe/return pipes is a little narrower than the latter as well). is 1/2" ID hose right for that or will it be difficult to get on? don't suppose there's a 9/16" ID heater hose?
1995 Celica GT convertible
2.2L 5sfe engine
bumperbozo is offline   Reply With Quote
Old 10-24-2011, 01:01 PM   #2 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
They're for your oil cooler.
If they're curved you should be getting those from the dealer, I don't think any one else carries them. And they're metric too, not standard.
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 10-24-2011, 01:06 PM   #3 (permalink)
i used gates 5/8" to replace the other heater hose lines, but they were a pretty tight fit. gates also has some generic molded hose, like right angle stuff that would fit without kinks (if there is an appropriate diameter!)
2.2L 5sfe engine
Old 10-24-2011, 02:09 PM   #4 (permalink)
UPDATE: just talked to another Gates tech support rep and he said he didn't have specific part numbers indicated for this use. He said 1/2" would probably work, but would be less likely to recommend the 5/8". I don't think i want to put 1/2" in such a difficult to reach location in case it fails. I would be willing to try 9/16". does anyone know what locally available brands make 9/16"?
2.2L 5sfe engine
Old 10-28-2011, 06:45 PM   #5 (permalink)
View carlr33's Photo Gallery
I used the factory curved hoses on my 99 convertable. There is one hose that I tried to use a straight hose replacement but there was to much bend to use it.
carlr33 is offline   Reply With Quote
