2nd gen 3sgte smoking on high boost - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2011, 07:14 AM   #1 (permalink)
drbos's Avatar
View drbos's Photo Gallery
Gen5 2nd gen 3sgte smoking on high boost
hey all,
i have a 2nd gen 3sgte smoking on high boost, not on idle and not on normal driving.
could it be my CT26 turbo leaking? or head gasket? there is some oil residue on the compressor inlet. any info would greatly be appreciated!
by the way it's a blue smoke
thanks,
Drucker
drbos is offline   Reply With Quote
Old 10-24-2011, 12:50 PM   #2 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
The residue is probably from the PCV system.
You can pull your down pipe and check for oil there [means leaking turbo seals], but it's easier to check your plugs first and check for oil.
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 10-24-2011, 08:36 PM   #3 (permalink)
drbos's Avatar
Does that mean pcv system is bad and need to be fixed. what need to do to fix pcv system? or will problem stop if get a new turbo?
what if I see oil on plugs..? what then?
thank you.
Old 10-24-2011, 08:56 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Theres a good chance the oil seal in the turbo is on it's way out. Pull the intake pipe off the inlet side of the turbo and see if there's excessive oil in the pipe and turbo.
The 3sgte has PCV, but no valve. And ususally, if the tube is clogged, it would smoke at idle.
I would also do as suggested above and pull the plugs and check their condition.
I would also do a compression test.Let us know what you find.
The Jedi Speeder at CarDomain
Old 10-24-2011, 10:03 PM   #5 (permalink)
drbos's Avatar
ok I will check the plugs and the inlet to turbo, like I said it does NOT smoke at idle nor driving normal but only on boosting you see a quick cloud of blue smoke. You can even smell it inside the car too.
Old 10-25-2011, 12:19 AM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Yeah, blue smoke is oil.
How many miles on it?. The CT26 uses a float bearing, making it very important to keep clean oil in it. Not to mention 100,000's of RMP's and high heat temps.
The seal in my original CT26 gave out, dumping a ton of oil into the cumbustion chamber, blowing the headgasket and cracking the #3 piston top.
