I was really close to doing the same swap until I talked to a mechanic who has done the swap and he told me that you need to get the 2wd turbo tranny???(never heard of this tranny being used in a 3S-GTE, but its what I was told)
you also need a downpipe, wiring harness, ECU, airflow sensor, MAP sensor, that should come with the motor, but are essential to get if you dont have. You also must make sure your drive shafts are going to mate up with your tranny. I believe you also need a fuel pump, either an after market one, or a turbo supra fuel pump will work. Plus theres modification needed to be done to the exhaust system.
Remember, this is what a mechanic who has done the swap has told me, if anyone else knows more things needed, or can correct me, please do so, as I am also interested in knowing exactly what is needed, as I am still indecisive of swapping the 3S-GTE or doing a 5S-FTE.
FS: 17" ADR Ryver w/Firestone Firehawks 235/45ZR17
MOMO Shift knob/ ebrake w/boots
