vibration issues when accelerating - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2011, 05:07 PM   #1 (permalink)
View ydeadhead's Photo Gallery
Car shakes real bad when it turns over and then at different speeds. 25-30 it'll shake more, along with 45-50 and around 70 mph.
Mechanic friend says motor mounts which would make since cause the one thats visible has cracks in the rubber.
But the shop my father takes the car into says it needs a new drive shaft.
Any opinions would be greatly appericated
ydh
ydeadhead is offline   Reply With Quote
Old 11-04-2011, 12:52 AM   #2 (permalink)
DCM
One with the farce
Gameroom cash: $106800
View DCM's Photo Gallery
Have you jacked up the car yourself and looked at the axles and mounts?
'92 ST185 All trac turbo
'92 AE95 wagon x2
'72 TE27
DCM is offline   Reply With Quote
Old 11-04-2011, 07:49 AM   #3 (permalink)
the lower mount i could see looked fine, the one on top (the only other one i could see was splitting in the rubber). Maybe i can get my lazy father to start caring about his car again and get this fixed.
Worn motor mounts can cause a lot of problems right? I mean excessive vibration cant be good.
Old 11-04-2011, 09:18 PM   #4 (permalink)
DCM
One with the farce
Yes they can cause vibration, I had a Camry that the PO had hit something with right on the engine mount that runs front to back on the earlier Camrys. The engine mounts that were on it were pushed out of alignment and the front one was broken, but I could hardly tell from looking at it that the crossmember was pushed up.
With the damaged parts, the car vibrated terribly at idle and at certain rpm's too. After replacing the broken mounts and bent crossmember, it ran like a dream.
'92 AE95 wagon x2
'72 TE27
Old 11-05-2011, 09:38 PM   #5 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Mine vibrated terribly at all times until I replaced all four mounts. I highly recommend buying OEM mounts if you plan to hold on to the car for any length of time. The two upper mounts (left and right) are only really available through Toyota, but the lower mounts are available at local parts stores, but those break down very quickly, especially if it has a manual trans. I replace all four less than 20k miles ago and the front and rear mounts are completely shot.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 11-06-2011, 10:44 AM   #6 (permalink)
posted in the wrong forum. This is the camry im talking about. But how quickly do the cheap mounts go out? My father isn't looking to throw a lot of money at the car
Old 11-06-2011, 04:13 PM   #7 (permalink)
DCM
One with the farce
Doesn't matter, basically the same layout. Throw in some cheap ones and see how long they last. Probably be fine since they're not going into a race car.
'92 AE95 wagon x2
'72 TE27
Old 11-06-2011, 07:18 PM   #8 (permalink)
thats what ended up happening. My father bought a complete set off amazon for $100. Too bad it wasnt more expensive im sick of driving this POS camry that has no power.
o and thanks for the help guys
