Originally Posted by RobMilkshakes
Well the 7th generation will definitely feel sportier than your camry. With the auto models the only issue that I would be aware of is before 2003, some 1ZZ-FE engines (the engine that came in the GT model between 00-06) had oil consumption issues, in 2003 Toyota redesigned the piston rings to solve the problem. Some of the eariler engines have this problem while others dont.
Yeah I know the 1ZZ-FE doesn't put out much more power than the 5S-FE but the Celica is so much lighter which is I guess where the sportier feel comes from!
Was the consumption problem common for the 00-02 models? Most of the Celicas I'm looking at are 2000 and 2001 models. After about 2002 the price nearly doubles since the later models are increasingly rare.
Also, is the 1ZZ-FE easy to maintain? I've really only worked on the 5S-FE which is about as straightforward as it comes.
