My 88 has the same problem. There is a wire attached to a control unit mounted on the firewall with a 7/8" OD heater hose leading in and out of it. When I remove the wire from the control unit and manually move the post/lever to the heat postion I get heat but then the wire moves on its own to the cool position and shuts down the heat while the post/lever is still in the heat position. If I shut the engine off for a while heat returns. I want to bypass the heat control unit with an on/off valve plumbed in under the hood but I am affraid the stupid wire will still be able to shut the heat off.
How do I deactivate the litte motor that operates that control wire?
'93 MR2 Turbo
'91 Dodge Turbo Diesel 4X4 p.u.
'88 Celica All-Trac
