Originally Posted by MR2Jedi
Start with checking the ignition system.
Check for a diagnostic code.
There aren't many codes that will appear without a check engine light as well:
http://www.autozone.com/autozone/rep...00c152801ccc73
Also, fuel system and filter, and depending on how long the rough idle lasts and depending on if you have any white smoke and coolant or oil usage, head gasket could be a culprit - heat will expand them to solve the problem after a few minutes.
They're the ones that come immediately to mind.
