bigger brakes on 1992 ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2011, 09:43 PM   #1 (permalink)
View OldElPaseo's Photo Gallery
Hi !
i have a 93 celica gt convertible. i also bought a 92 gt hatchback for parts.
I took the brake brackets, caliper and discs from the 92, sandblasted, painted and cured the paint, they are beautiful. but when i installed them on my 93 celica, i noticed the rotors were bigger and the bracket is a little longer ?
arent the brakes the same ? could it be that those were from an all track celica ?
the problem is that everything fits , but the brake pad goes over the outer edge of the rotor by about an inch. could it be that the 92 had a different knuckle ?
tanks !
OldElPaseo is offline   Reply With Quote
Old 11-13-2011, 06:40 AM   #2 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
Well whats the manufacture date for the hatchback?
Today at work, I'll check a few part numbers, see if anything changes over.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 11-14-2011, 01:20 AM   #3 (permalink)
DCM
One with the farce
Gameroom cash: $106800
View DCM's Photo Gallery
I have a '91 RHD GTfour and a LHD '92 All-trac...the rotors on my '92 are about an inch bigger diameter than on the '91.
'92 ST185 All trac turbo
'92 AE95 wagon x2
'72 TE27
DCM is offline   Reply With Quote
Old 11-14-2011, 05:26 AM   #4 (permalink)
i dont know the manufacture date for the 92 gt hatchback. but i could check out the manufacture date on my 93 convertible today.
i think ill just go to an autozone and ask him to show me the brakes before i buy the new ones, maybe ill find out that way. ill have to start a list of the components for this car.. brakes from 92, engine from 94.. gettin complicated
Old 11-15-2011, 01:07 AM   #5 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
92/93 brakes are the same. 92s definitely aren't bigger than 93s. Production start date for 92s would be Sep 91. Someone probably got the wrong brakes put on the car, they bolt onto each other.
Someone probably cheaped out and bought FWD rotors for your 91, AFAIK all ST185s had the same brakes [other than the 2 piston calipers on the early ones].
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 11-15-2011, 02:11 AM   #6 (permalink)
DCM
One with the farce
The '91 and '92 that I have are totally different....I mean other than the fact that they're both disc setup, obviously. Did the RC/CS model use larger brakes? My '92 has the entire drivetrain from one swapped into it.
'92 AE95 wagon x2
'72 TE27
