Water pump dying? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2011, 12:23 PM   #1 (permalink)
View stormhawk's Photo Gallery
Water pump dying?
I have a 1990 GTS with a transplanted 1996 S5HE 2.2 motor. This summer I started getting overheating issues and I believe my water pump is dying.
Here's the symptoms; car will run nice and cool on the freeway doing 70 with the tach turning at 3.5k. As soon as I get off the freeway and RPMs drop the coolant temp will spike almost into the red. Accelerating from the stop will drop the temp but it will hover near the high end of the middle till I get back on the freeway or RPM's go back up. It does the same thing when climbing hills or when the engine is under load. It did it bad this summer when it was hot out and I was running the AC. Bad enough that it boiled over a couple times. The radiator is brand new and just based on the symptoms I'm thinking water pump.
Am I right on this or is there something else I can check? The thought of tearing apart the motor to replace the pump isn't something I look forward to.
Thanks.
stormhawk is offline   Reply With Quote
Old 11-25-2011, 07:46 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
From what you stated, I would suspect radiator fan(s) before water pump.
Check to see that the fan(s) are running at idle after car has been running awhile.
The Jedi Speeder at CarDomain
Old 11-27-2011, 06:40 PM   #3 (permalink)
The fan is running fine, also replaced the thermo this afternoon. Any other ideas?
Old 11-27-2011, 07:32 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Thermostat woulda been my next suggestion.
Strange.
You said you have a new radiator. Have you confirmed that the heater core was bled properly?
Old 11-27-2011, 09:06 PM   #5 (permalink)
Heater core has been bypassed (it was bypassed when I bought the car, not sure why). The car only has a single fan, would a dual fan setup be more practical? Scratching my head on this one too.
Old 11-27-2011, 09:59 PM   #6 (permalink)
RobMilkshakes's Avatar
Gameroom cash: $373615
View RobMilkshakes's Photo Gallery
A single fan should be sufficient. With the symptoms and temp change being consistent I wouldn't really suspect air in the system. Honestly, with a good thermostat,the water pump is the only other thing I would suspect.
'11 Kawasaki Ninja 250R, '12 Mazda2
RobMilkshakes is offline   Reply With Quote
Old 11-28-2011, 12:06 AM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Only if it originally had 2.
With all thats been said, I agree.
Old 12-04-2011, 07:00 AM   #8 (permalink)
View engine1CD's Photo Gallery
Warm up engine and check-compare temperature of rubber hose from head to radiator top placed and hose from radiator to engine block bottom placed, on warm engine there should be a little difference in temperatures of both hoses few degrees, checked with hand on hose. If same occur after, engine is warm up, probably there is a problem with sensor for inlet temperature of water, located on head near inlet pipe. Give different info to ECU of your vehicle.
engine1CD is offline   Reply With Quote
