Plastic Window/Lock control piece - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2011, 06:50 PM   #1 (permalink)
View agusted's Photo Gallery
The plastic piece of the door that holds the window button and door lock button is loose on my 1999 Celica(convertable model). Should I just glue it or is there a better more legitimate way to get it to stay?
Also, the rear drivers side window is sometimes unresponsive. Sometimes it works when I press the button; sometimes not. Any idea what could be causing this?
Thanks.
agusted is offline   Reply With Quote
Old 12-03-2011, 09:11 PM   #2 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
The "better" way would be to replace the trim piece. Sounds like one or more of the clips are broken. Make sure before you order a new one.
The window problem is probably the window motor, but it may be the switch.
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 12-04-2011, 08:34 AM   #3 (permalink)
View engine1CD's Photo Gallery
Install new clips, on left trim. And check master window switch. on left door.
engine1CD is offline   Reply With Quote
