You probably bought an aftermarket distributor, they don't tend to be as good as Toyota ones, which are usually pretty reliable.
Do you have any kind of warranty on the dist?
And what failed, the dist or the coil inside the dist?
Not a lot you can do as far as a distributorless system, the only 5SFEs that came without are the 97 ^ Camrys, and they're OBDII so it would take a lot of work/money to make that work on your car.
Your cam and crank sensors are inside the dist so it's not easy to get rid of it.
92 Alltrac, 85 PU
