So it's been a while since I posted and I figured I give you guys an update on the '90 GTS' progress.
The car ended up not being driven for about three months while I was working put of state. When I came back I replaced the oil pump seal, timing cover seals and the dizzy to try to fix a mysterious oil leak. It was running awesome with tons of power and a nice smooth idle. I drove it for about two weeks and the groan and clunk from the suspension started to get worse and worse. I replaced all four struts, front strut mounts, rack & pinion and rear stabilizer bar links.
I did all this over the course of three days and the suspension still has issues; front wheel bearing, bad pull to the right and a strange squeak that keeps time with vehicle speed. Both front and rear motor/trans mounts are shot and a tie rod end got grrr'd up during replacement of the r&p. There is also a stubborn oil leak near the back of the motor I am trying to trace.
It's been a really long week of wrenching on this car. Luckily, it looks like it's almost ready for commuting. I'm taking it in for an alignment this weekend and then I'll be able to tell if all that suspension work has paid off. The motor mounts are gonna have to wait for a while, ditto on the persistent oil leak. There's a big part of me that wanted to just drive the car into the desert, pour gasoline on it, set it on fire and shoot it full of holes with my Sig 556. I resisted the temptation to murder the Celica money pit in the hope that all the work I've put into it will pay off. Here's hoping.
