is this 5sfe crank swap possible? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2012, 09:29 PM   #1 (permalink)
View rotundra's Photo Gallery
I am rebuilding a '90 celica 5sfe. The bearing spun so i need a new crank. The boneyard has a good crank from a ' 95 Camry, The only difference I can see between the 2 cranks is the gear that drives the balance shafts.
Will the Camry crank work in my Celica(non-countershaft) block?
rotundra is offline   Reply With Quote
Old 02-02-2012, 02:27 AM   #2 (permalink)
Gameroom cash: $290400
View '88 All-Trac's Photo Gallery
Yep. Later-model Camry 5SFEs have been swapped into Gen 2 Camrys without issue. You when doing the engine swap, you remove the balance shaft and reuse the 3S oil pan.
You can run the Camry 5S cranks without the balance shaft no problems.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is online now   Reply With Quote
