Need help 90 celica gts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2012, 09:22 PM   #1 (permalink)
View Benfree25's Photo Gallery
I just replaced both of the cv axels in my 1990 gts 5speed standard transmission.. Now there are two small areas where it is leaking which i assume is on both sides. Before i do this seven hour job all over again to fix it can someone tell me what parts i need?? is it the seals i couldve broke??
Benfree25 is offline   Reply With Quote
Old 02-01-2012, 09:23 PM   #2 (permalink)
it is leaking transmission fluid
Old 02-01-2012, 10:13 PM   #3 (permalink)
DCM
One with the farce
Gameroom cash: $106800
View DCM's Photo Gallery
Are you certain the axles are popped in all the way? Just wondering.
'92 ST185 All trac turbo
'92 AE95 wagon x2
'72 TE27
DCM is offline   Reply With Quote
Old 02-01-2012, 10:18 PM   #4 (permalink)
No I'm not positive? It isn't making a noise and when I first put them in and chrcked to see if both sides turned and they did
Old 02-02-2012, 02:24 AM   #5 (permalink)
Gameroom cash: $290400
View '88 All-Trac's Photo Gallery
Did they make a little "snap" feeling when the shafts went in? There are two snap rings- one for each shaft- that secure the shaft inside the differential.
Did you replace the seals when you replaced the shafts? A damaged seal will also leak.
'88 Camry All-Trac DLX 3SFE 5-speed manual
'91 Camry base-model 3SFE 5-speed manual
'92 Geo Tracker 4x4
'78 Dodge LeisureCraft
'89 Saab 900 Turbo
'90 Ford Ranger 4x4
'88 All-Trac is online now   Reply With Quote
Old 02-02-2012, 05:35 AM   #6 (permalink)
See i didn't replace the seals so that is my guess for what is causing it to leak. And yes I did snap them into place.
Old 02-02-2012, 07:18 AM   #7 (permalink)
Could someone tell me what type transmission I have so I can order the seals? I was going to order them at autozone. But he said there are four different kinds and I need to find out which on it is first.
Sent from my Autoguide iPhone app
Old 02-03-2012, 01:31 AM   #8 (permalink)
DCM
One with the farce
Under your hood on the firewall there is a square aluminum tag that has that information on it. There should be a line that says something like "A/T", followed by an axle code and transmission code.
'92 AE95 wagon x2
'72 TE27
Old 02-03-2012, 06:29 AM   #9 (permalink)
Thank you. I'll look when I get home!!
Tags
1990, celica, gt-s, help me, transmission
