How TO Change Timing Belt on 87 celica GT?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2004, 05:03 PM   #1 (permalink)
View CEOtimeccles's Photo Gallery
Hey whats going on everyone, i was wondering how I would go about changing the timing belt on my 1987 toyota celica GT? Can anyone take a couple of snap shots or give me directions?
Any one with any knowledge of how to change the timing belt please contact me via e-mail at: dj_lyricx@hotmail.com or through this message board.
Thank You
CEOtimeccles is offline   Reply With Quote
Old 06-11-2004, 10:27 PM   #2 (permalink)
camrys blow off too!
View silverstreakin's Photo Gallery
not to be a jerk, but if you plan on working on it alot, just buy a haynes manual. they arent that expensive, and give decent info.
also did you do a search before you asked your question?
93 toyota mark II tourer V
1jz-gte twin turbo goodness!
93 toyota scepter turbo stored back in the states!
*in loving memory rapeacivic*
silverstreakin is offline   Reply With Quote
Old 06-11-2004, 10:33 PM   #3 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
Pull off cover, and I'm sure you can figure it out from there.....make sure to realign the timming marks on the gears when finished.
- Vince
VVT-i Owns is offline   Reply With Quote
Old 06-12-2004, 01:27 AM   #4 (permalink)
sad thing is, its almost that easy. the only thing that sucks is the motor mount, and getting the crank pulley off
Old 06-12-2004, 06:51 PM   #5 (permalink)
View 86er's Photo Gallery
The bitch is not easy trust me.
It's only easy if you have the motor out.LOL
But just take your time and you can do it, it will be an all day job.
Steps:
1. take the altonator off with the braket(more room)
2. take a jack and a block of wood and place that wood inbetween the oil pan and the jack.
3. Take the tention off of the motor mount.
4. Get under the car and with a 14mm. deep socket, losten the nuts on the bottom of the motor mount.
5. Losen the 17mm. main motor mount bolt(chassi braket)
6. Take the motor mount out.
7. Take 14mm. socket and take all 3 bolts that hold the motor mount braket to the block out.
8. Take the braket out.
9. Get that last bolt that you couldn't reach with the mount in.
10. You should be able to handle it from here.
Good luck and happy working.
-Andy.
JDM 3sge motor
8mm NGK Spark Plug wirers
2 1/2in. exhaust from cat back
Gutted cat
Running half open
86er is offline   Reply With Quote
