91 celica smokes from water outlet housing?
My engine started to overheat and I have a very specific stream of smoke coming from, what I believe, is the water outlet housing. I'm pretty sure the hoses that are connected to it are heater hoses of some sort. My question is what would make that specific area smoke?!? I have oil, I have plenty of coolant, although there was coolant leakage the first time I noticed the smoke underneath the car right about dead center, there wasn't a distinct epicenter of fluid, which lead me to rule out failing water pump. Got the diagnostic codes and the coolant temperature sensor checked out fine as well. Did not see any specific spots for leaking, just coolant sprayed everywhere on the underside of the car, behind the engine, towards the middle of the car and smoke coming from that water outlet housing.
