91 celica st eng. swap? HELP - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-07-2004, 03:25 PM   #16 (permalink)
View W8NLine's Photo Gallery
Ive done lots of work to my car already thats why im trying to keep that and drop and engine in it. I mean i got a body kit which i had to custum fit lots of work..Lowered it, got 17's, fresh tourch red paint, tv and ps2 and all that, and some custom interior. I got to much time in that car to get another one. So u are saying my trannay and everything will work, it would jsut be smart to get stronger brakes, i do have new rotors on it thought, alot bigger then the ones it came with..
W8NLine is offline   Reply With Quote
Old 07-07-2004, 04:36 PM   #17 (permalink)
Well when i get this 3sgte am i going to have to get a new tranny also. cause with the st its got quit the weak tranny.?????
Old 07-07-2004, 05:01 PM   #18 (permalink)
View enufced904's Photo Gallery
actually you may want to look further in to the swap than what people are telling you. although the all trac does use the 3SGTE it doesn't necessarilly mean that it is suitable for your car. try using the 2nd generation mr2 3sgte. it is nearly a direct swap except that, yes you would have to swap out the motor mounts. also, your stock transmission would not be suitable to use because it would not bolt up. the stock exhaust doesn't bolt up either so you may want to check into an aftermarket e for the car. just make sure you look around before making any permanent decisions.
Future plans: suspension, 3sgte or 4AGE swap
enufced904 is offline   Reply With Quote
Old 07-07-2004, 05:13 PM   #19 (permalink)
Well if the 3sgte is to much..How about The 4A-GE 20 v engine fit my celica st. Will i have mounting problems and what will i need to do with the tranny..THANKS AGAIN
