89 Celica GT conv won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2004, 11:51 PM   #1 (permalink)
View briannc's Photo Gallery
Unhappy 89 Celica GT conv won't start
Hi,
I have a problem I can't diagnose. I let my sister borrow my Celica and while driving, the engine and whole electrical system cut out. This of course was dangerous, but luckily nothing bad happened and she was able to stop the car. She said there was a small fire near the battery.
After towing the vehicle to my place, I can see no fire damage. The tow operator had disconnected a battery terminal, so I reconnected this and the electrical system seems to work fine. When I try to start the car, I can hear a slight whir, but the engine doesn't try to crank. After trying several times, I once heard the starter misfire with a loud screech, which it would do in the past on occasion.
A few years back, I had the same problem as my sister- I was driving and everything cut off. But at the time, I noticed one of the battery terminals had come loose, and I reconnected it. I immediately went to an auto shop and I had a new battery installed and they supposedly fixed my connections, but maybe something went bad again.
Any opinions/suggestions?
briannc is offline   Reply With Quote
Old 07-25-2004, 03:06 AM   #2 (permalink)
89CelicaGTTurbo's Avatar
View 89CelicaGTTurbo's Photo Gallery
check the fuse box. its located right next to the battry, maybe some of the fuses or relays blew out. fuses are easy to replace relays are expensive.also check the connection to the starter. if that is lose it can cause a lot of connection problems.
89CelicaGTTurbo is offline   Reply With Quote
Old 08-07-2004, 02:10 AM   #3 (permalink)
Rick89GTS's Avatar
View Rick89GTS's Photo Gallery
If all power cut out while driving, I'd guess that it was associated with the alternator. Double check the connections, especially the ground.
Rick89GTS is offline   Reply With Quote
