'92 GTS Idling rough - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2004, 11:08 PM   #1 (permalink)
Heavy Sleeper
View 3SGTE@daSpeedof's Photo Gallery
Unhappy '92 GTS Idling rough
I have two problems. First is that my celica is idling very rough, I just changed my spark plugs, oil & filter change. What else can I do to fix this problem???
I am going to check the timing, but I'm not sure what else could be causing it?
Second problem is that I think I have a short somewhere because every three days my battery dies, and needs a boost. I just bought the battery two months ago. I also replaced my alternator. What else can I check, or what should I do to fix it?
'92 GTS 3sgte w/LSD, 7th Gen GTS Gunmetal rims.
Salon Spa Software for all your management software needs.
http://salonspasoftware.com
3SGTE@daSpeedof is offline   Reply With Quote
Old 07-29-2004, 12:13 AM   #2 (permalink)
View celica kid's Photo Gallery
man i had both of these problems my friend. first off check all the connections and leads to and from your battery to your alternator. i replaced my alternator after having my old one rebuilt which didnt do anything... but as far as the idling problem... my engine used to shake like crazy at idle. i did many things...including a head job and nothing worked...then i randomly changed my fuel injectors like 3 weeks ago...and boom all better....its kinda of expensive but it worked wonders for me. lost the shake got better acceleration and stuff.. so yea fuel injectors fixed it for me.
Cameron Crooks™
celica kid is offline   Reply With Quote
Old 08-01-2004, 01:49 PM   #3 (permalink)
View fleabizkit's Photo Gallery
also try changing the map sensor.. it can cause the rough idle.. as far as the battery problem, i dont know what to tell ya bro... good luck
fleabizkit is offline   Reply With Quote
Old 08-02-2004, 02:19 PM   #4 (permalink)
View lloydjv's Photo Gallery
try to disassemble your throttle body and ISC valve and give them a good thorough cleaning as well.
And yes, bad ground points can cause those symptoms, too.
Just for laughs, check your motor mounts, too.
lloydjv is offline   Reply With Quote
