I removed the headliner and checked the wiring again and it all looks good but there is a plug in the wiring harness that does not have anything plugged into it, (w/all others plugged into motor) is something suposed to be plugged in there? The motor itself turns easily and the roof itself moves smoothly when opened and closed manually.
As I stated in my first post it I could not find power from any of the wires going to the motor and the fuse in the kick panel is good, is the relay supposed to be plugged into the currently empty plug in the harness under the drivers side of the headliner?
If I can't find the cause of the problem soon I am just going to open and close it manualy as this is turning out to be more trouble than it's worth.
Thanks for the suggestions, I really appeciate it, I just wish I could find the problem.
Thanks again,
Kurt
93 Celica GT
