cruise control and brake light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2004, 09:15 PM   #1 (permalink)
View volrath_2001's Photo Gallery
this is kinda a strange one when I bought my 92 GT I was told by my sister that the brake light on the dash would almost always stay on and that the cruise control didn't work... but if I ever saw the brake light goes off I would have my cruise I have no idea why this is or if there is a way to fix it. It really isn't that big of a deal just a little annoying if anyone know anything about this please let me know thanks in advance
volrath_2001 is offline   Reply With Quote
Old 09-14-2004, 01:15 AM   #2 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
The reason the cruise control doesn't work is because it thinks your brake/emergency brake is on. If I had to guess, (which I'm doing) I would say the switch to your emergency/hand Brake is sticking and causing the dash brake light to come on and keeping your CC from engaging. Otherwise your brake lights on the back of the car would also be staying on.
Also double check the brake fluid resevoir, that could also be another reason the "brake" light is coming on.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 10-13-2004, 08:37 AM   #3 (permalink)
cmo
View cmo's Photo Gallery
cruise control and brake light - me too!
I have an 89 celica and have the EXACTLY the same problem. (emerg. brake light is on at all speeds above about 10km/hr and cruise doesn't work unless brake light is off which rarely happens) Brake fluid was just checked - was going to take the car in today and see what to do, if it something like the switched sticking, what could this cost to fix it?? did you ever fix yours or you just drive it as is? Anyone can help with an estimate of cost?
cmo is offline   Reply With Quote
Old 10-13-2004, 09:21 AM   #4 (permalink)
no
I still haven't had it fixed because I have no Idea what it is. if you go and get it fixed let me know what it is thanks in advance
Old 10-14-2004, 08:43 PM   #5 (permalink)
Not so Noob now!
es250nut's Avatar
If it is the handbrake switch, I would figure you could get it for around $30 from the dealer. Or you could go to a wrecking yard and get it for a couple bucks.
Try using some electronic contact cleaner on it, the switch is located on the handbrake frame, you may have to remove the center console to get to it.
Old 10-14-2004, 10:15 PM   #6 (permalink)
Official TN OT Hater
Waghle's Avatar
View Waghle's Photo Gallery
anyone else with this same problem?
i am considering on getting a celica, but i suppose this small problem wont really matter.
Man Boobs. LOL...if it wasn't so funny, I'd ban you right now.----RningOnfumes.
Originally Posted by Qslim View Post
I think it's safe to assume all chicks like to fart on different types of food.
Waghle is offline   Reply With Quote
Old 10-15-2004, 04:56 PM   #7 (permalink)
View 2000GTS's Photo Gallery
this happens on a lot of vehicles. did you have a break job before this started happening?
2000GTS is offline   Reply With Quote
Old 10-15-2004, 05:50 PM   #8 (permalink)
Immortal
View Kwanza's Photo Gallery
Check your brake fluid resivoir. Low brake fuild can trigger the brake light.
It's ok to be naked, girl... I'm an Artist!
95 AT200 Celica ST: Stockish Daily Driver
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with JDM Smallport 4AGE and goodies...
84 AE86 Corolla GT-SR5 Hatchback: GT-S Swap with Silvertop 20 Valve 4AGE
91 SW2X MR2 N/A: Rare hardtop cruiser
Kwanza is offline   Reply With Quote
Old 11-26-2004, 11:25 PM   #9 (permalink)
View bill3135's Photo Gallery
I'm sure the "brake" referrred to above is the parking brake or handbrake, and the "brake light" is the indicator on the dash that indicates the brake is on. It says "BRAKE" - my wife's 92 Celica Convertible has the same problem, and so I bought a new switch from the dealer ($36 plus tax) and spent hours taking out the center console to expose the handbrake assembly. Sure enough, the old switch was bad according to my ohmmeter - it reads open all the time, while the new one reads open only when depressed. This is a problem; I'm sure the switch normally supplies a ground to the light, allowing it to illuminate, and opens that ground when the handbrake is released, turning off the light - so if the switch is open all the time, the light should never come on. I replaced it anyhow, and sure enough, the light stays on all the time. I took more of the console out, looking for a short in the wiring, but didn't find anything. I'm thinking now that the circuit has to go through some kind of junction box and is tied to something else that isn't working right.
Can anyone help?
bill3135 is offline   Reply With Quote
Old 12-05-2005, 05:17 PM   #10 (permalink)
View rayban68's Photo Gallery
Is it possible to hook the switch up the other way around?
rayban68 is offline   Reply With Quote
Old 05-17-2007, 07:43 AM   #11 (permalink)
View Gold Bear's Photo Gallery
Try un-plugging the electrical connector next to the brake cylinder resevoir.
Gold Bear is offline   Reply With Quote
