88 celica alltrac won't start! help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2004, 01:24 PM   #1 (permalink)
View TurboEh's Photo Gallery
here's the deal:
NO CODES PULLED
COIL IS GOOD (tried 2 of em, tested resistance etc. no problems)
CHANGED IGNITER with one of my friend's and still didnt fire
CHANGED DISTRIBUTOR and it worked for a week.
CHECKED & CLEANED GROUNDS
it's an 88 165 with stock ignition. Getting no spark. getting power to the igniter, and power to the coil.
is there anything else i can check??
i've seen posts about people having the same problem but cant find a post saying what cured it (if anything).. so i know i'm not alone!
mike
1988 st-165 not stock...
TurboEh is offline   Reply With Quote
Old 09-08-2004, 05:48 PM   #2 (permalink)
View njno's Photo Gallery
Check your crank sensor..
njno is offline   Reply With Quote
Old 09-08-2004, 06:03 PM   #3 (permalink)
where is it located? i dont have a service manual for the car...
Old 09-09-2004, 06:00 AM   #4 (permalink)
I belive it's behind the crank pully.
Old 09-09-2004, 10:40 AM   #5 (permalink)
ok because i thought that it only had pickup coils in the distributor, and didnt have a Crank Angle Sensor. ..
Old 09-09-2004, 07:42 PM   #6 (permalink)
Your right, I'm bad....
There really isn't much to that system, Pick up coil, Igniter, Ignition Coil, ECU.
If your getting power to the coil + side and no intermittent ground on the - side when cranking it a primary ign problem.
You say you changed the dist. and it worked for a week tells me someplace you hit a connector while replacing it that is not connected right or is failing.
Also how do you determine you have no spark?
Old 09-09-2004, 09:09 PM   #7 (permalink)
View Zrain's Photo Gallery
did u try kicking it?
1991 Toyota Celica Red, Gray Interior, 5spd, 2.2L
My New Toy 3-1-04
Zrain is offline   Reply With Quote
Old 09-10-2004, 09:47 AM   #8 (permalink)
actually last night i punched the igniter and coil and distributor and it started..... haha...
i think there is a connection that is effed going to the dist. , i checked spark by removing the 2ndary wire from the coil and holding it near ground. nothin... then after i smacked everythign around it started to spark. threw the wire back on the cap, and she fired up.
