Intake is Dirty as Hell - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2004, 01:46 AM   #1 (permalink)
View Zrain's Photo Gallery
so im deep into my car looking overthings. and im pulling aprt my throttel body and MAN IS IT DIRTY IN THERE!@#%!^
so i need some advice. whats thebest way to clean all that up?
much of the crap in there is from the CPV that runs from the valve cover to the TB, and a bunch is from the EGR (i think)
not positive. any ways. id like to clean out all of the Dirt and Carbon thats in there..
another thing to note was the car ran with a bad airfilter for a long time. (chick who owned it before me)
im going to go back to regular oil soon, car dosent sound so hot with the Mobil1 Synth i put in it..
it also needs Bucket shims done on it.
(old car Bluse )
1991 Toyota Celica Red, Gray Interior, 5spd, 2.2L
My New Toy 3-1-04
Zrain is offline   Reply With Quote
Old 09-11-2004, 03:26 PM   #2 (permalink)
camrys blow off too!
View silverstreakin's Photo Gallery
try the 15w50 mobil 1 before you go completely back.
93 toyota mark II tourer V
1jz-gte twin turbo goodness!
93 toyota scepter turbo stored back in the states!
*in loving memory rapeacivic*
silverstreakin is offline   Reply With Quote
Old 09-11-2004, 09:42 PM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
also putting a small fuel filter between the pcv and the tb helps cut back on the crud
^ and leaving it that way!
Old 09-12-2004, 12:08 AM   #4 (permalink)
well aparently now the car sounds better...
thing is one way one day another way the next.
as for the crud im going to look into bypassing the EGR and the using a filter for the PCV.
My New Toy 3-1-04
Old 09-12-2004, 01:25 PM   #5 (permalink)
Always Bored
View hachi-rocu's Photo Gallery
breather
I have never done it for the money.......except for that one time
hachi-rocu is offline   Reply With Quote
Old 09-12-2004, 08:34 PM   #6 (permalink)
Gameroom cash: $147537
Get 2 can of Throttle body cleaner, follow instruction on bottle. Plus remove vaccum hose one at a time and spary the cleaner in both ends. Put the hose back and go to next one. Make sure you spray into the ICV on the bottom of the TB. After that reset your ECU.
Old 09-13-2004, 04:15 PM   #7 (permalink)
View 02_SLE_6's Photo Gallery
you have a 91 eh? castrol makes high mileage motor oils for engines 70,000+ i believe?
02_SLE_6 is offline   Reply With Quote
Old 09-13-2004, 06:25 PM   #8 (permalink)
i already have Mobil 1 5w30 Synth in it at the moment..
allright!! update:
Took the throttel body off the car and Drenched it in Carb/Throtel body Cleaner. and then sprayed a ton of it into the intake mainfold and cleaned out all the crap!!
then instaled an inline Small mottor Fuel Filter on the CPV just like Pineapplelaw has on his setup. its a fram filter that came with all the stuff i needed to do it.
and while i was at it i used GUNK's Engine Brite Foam and Deagreaser on the mottor and gave the hole intire bay a good Washing.
now all i need to do is Do a tune up and evrything will be just fine.
My New Toy 3-1-04
Old 10-20-2004, 10:20 PM   #9 (permalink)
Banned
View fiveSFE's Photo Gallery
it run better?
fiveSFE is offline   Reply With Quote
Old 10-21-2004, 04:24 PM   #10 (permalink)
View 2000GTS's Photo Gallery
try using carb cleaner to spray down the throttle body it works descent..
2000GTS is offline   Reply With Quote
Old 10-22-2004, 10:55 AM   #11 (permalink)
ne cleaner?
Old 10-22-2004, 11:23 AM   #12 (permalink)
GT-i Crew
lcarocha's Avatar
View lcarocha's Photo Gallery
Are carb cleaner and TB cleaner the same thing...?
I've always used carb cleaner since we dont get any TB cleaner around here but if I'm doing wrong I'd like to know before I damage something
Luis C.
92 Celica GT-i (ST182)
2nd Gen 3S-GE
Caracas, Venezuela
http://www.cardomain.com/id/luis_c
lcarocha is offline   Reply With Quote
Old 10-22-2004, 11:37 AM   #13 (permalink)
trebor_9513's Avatar
View trebor_9513's Photo Gallery
My dad's a mech. and he always said that I should never used carc cleaner on a tb unless it was a dual cleaner that specified both. But, then again when we were out he used it on the tb and said don't do this! This isn't our car!
trebor_9513 is offline   Reply With Quote
Old 10-22-2004, 11:41 AM   #14 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
There is no point in filtering the PCV system while the EGR is still active. 99% of the shit in the intake track is burn on, built up exhaust. NOT oil from the PCV system.
If you want that shit to stop building up every few months, you have to block off your EGR system.
To clean it off you need some TB cleaner, and a wire brush. A dremel using stainless steel brushes and a flexible extension work wonders. (stainless steel doesn't spark on Aluminum intake. Feel free to spray it with cleaner, wait a min or two, then hit it with the wire brush while it's still wet)
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 10-22-2004, 11:45 AM   #15 (permalink)
The pcv filter is good just in case of failure. My wifes honda has a knack of tearing up its pcv. Plus its a good idea, venting always occurs. Why not help keep the air as pure as possible. Definitely doesn't hurt anything & cost is minimal.
