Well thats just down right simple.
2 screws located on door jam side of door (see when open)(capped)
1 screw located on hinge side of panel (capped)
1 screw located where the door handle is (capped)
1 screw located on under side of arm rest
1 screw located down by the door pocket, it is capped with a big cap, acts as a partition in the pocket
1 screw located behind the door handle, you take it out after you remove the door handle (I think, this one might not do with door removal, take out the rest and see)
Once all screwes removed, grab bottom of door and pull, clips hold it on, so you dont need alot of force. Once thats done, the door panel has to be pushed upwards to unhook it from the legde, then minus the wires, the panel is off
