1993 Celica with a fluctuating idle...What's Wrong? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2004, 12:36 PM   #1 (permalink)
View calico2002's Photo Gallery
My 1993 Toyota celica has started to idle really poorly. when it idles good the RPM's stay around 1000, but every once in a while it will start to fluctuate and it will drop down to aroun 150rpm's, almost die, and then it will bounce back up to around 1200. It will then repeat this. Does anyone know what causes this and how can I fix it?
Thanks for your help
calico2002 is offline   Reply With Quote
Old 09-30-2004, 02:19 PM   #2 (permalink)
Gameroom cash: $147537
ICV (Idle Control Valve), open up intake and clean throttle body especially the holes at the bottom of it. Reset ECU after you finish and set timing and idle again. If that fail, you mau need a new ICV.
Old 09-30-2004, 08:34 PM   #3 (permalink)
View black_at180's Photo Gallery
check vacuume
Helping prevent the spread of
rice one, one fcker at a time
black_at180 is offline   Reply With Quote
Old 09-30-2004, 08:51 PM   #4 (permalink)
View toyotafan's Photo Gallery
clean the equivilent of the Mass air flow sensor .... ussually located near the air filter
toyotafan is offline   Reply With Quote
Old 10-01-2004, 12:41 AM   #5 (permalink)
View TRDcelicaGTFOUR's Photo Gallery
vaccuum
FS: 17" ADR Ryver w/Firestone Firehawks 235/45ZR17
MOMO Shift knob/ ebrake w/boots
TRDcelicaGTFOUR is offline   Reply With Quote
Old 10-05-2004, 05:59 PM   #6 (permalink)
I know I can't spell (sniff , sniff) vacuum
Old 10-05-2004, 07:23 PM   #7 (permalink)
View toylover's Photo Gallery
It uses a MAP dude.
There was a post in the hardcore/tech section a while ago about properly cleaning your IAC valve, do a search for it.
Do you have an intake?
toylover is offline   Reply With Quote
Old 10-05-2004, 11:30 PM   #8 (permalink)
thats why i said the equivelent of ...... Map and maf may be different but the do the same job
Old 10-06-2004, 10:49 AM   #9 (permalink)
MAF need cleaning, MAP don't, got a inline filter already and no air is passing thtough the sensor. Work totally differently and placed at different end of the intake manifold.
They're "equivelent" but kinda miss leading
Old 10-06-2004, 08:04 PM   #10 (permalink)
learn something new everyday
Old 10-11-2004, 10:24 AM   #11 (permalink)
View 2000GTS's Photo Gallery
check for vacuume leak or you may need a new MAF sensor
2000GTS is offline   Reply With Quote
Old 10-12-2004, 09:40 AM   #12 (permalink)
Old 10-12-2004, 11:23 AM   #13 (permalink)
SSSSSEEEEEEE!!!!!!!!!!!! I am not the only one that is ignorant about these small engines.......
Old 10-12-2004, 12:14 PM   #14 (permalink)
trebor_9513's Avatar
View trebor_9513's Photo Gallery
has the original problem been fixed? just a thought, have you changed the air filter? Are you still running a filter that has to been changed out every 6 months or have you switched to a reusable?
trebor_9513 is offline   Reply With Quote
Old 10-12-2004, 12:49 PM   #15 (permalink)
Only if people will read before they post
