im doing a 5s-FTE, but at the moment im taking my time (im up north so no sence going nuts with snow on its way)
the acorcding to some the 5s is stronger then the 3s, while others say the 3s is stronger then the 5s, at any rate its erelivent if you sticking to stock components of the 3sGTE turbo setup.
the 5sFTE is a good setup for your money, upto 18PSI with intercooler is the curent "safe limit" acording to some, but alot of people with this setup stick to 8Psi max, and no intercooler.
the internals will not fail you if you stay under 8Psi, (IE: your boost wont kill them, somthing else might but thats beond this argument at the moment) if you go over, just be shure to use an intercooler and you should be safe.
as for the $ to Power comparison, the 5sFTE is about 10:1 better then the 5sGTE, given the fact that it can be done with out even taking the mottor out of the car, or swaping the ECU.
the 5s-GTE requires more work for relitivly the same gains.
the FE head dose have one advantage over the GE head and thats Torque. given its desine and cam profile (econo car).
dude, do this: Get the 3sGTE exhauset Mainfold, and the 3bar map, and an adapter plate to convert to t3/t4 hybrid turbo, then get a decent t3/t4, for like 500 bucks or so, and then bolt it all up with a bost controler. run 8Psi, and behappy. you will have good power, goot Torque, a nice sounding car, and it will last you. if u need more power look into an intercooler, and some good tuning tools. and get it Tuned.
1991 Toyota Celica Red, Gray Interior, 5spd, 2.2L
My New Toy 3-1-04
