Help me with my drum brakes!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2004, 01:50 PM   #1 (permalink)
View 89_3SFE's Photo Gallery
Guys, I've got an 89 GT (3SFE) with front disk and rear drum and I replaced everything, including the drum itself, but I can tell that the shoes on the back are rubbing against the drum while I'm not braking. I adjusted everything as far back as I could, but they still rub. It was even kind of hard to put the drum on. They don't make noise, except a squeaking sound that repeats faster the faster I drive. Anyone know how to adjust them more, or should I just wait till they wear off to the point where they're not rubbing anymore? I know I replaced everything just as it was in earlier and didn't make any mistakes. Anyway, if you can help, I really need it. Thanks a ton!
89_3SFE is offline   Reply With Quote
Old 10-17-2004, 03:24 PM   #2 (permalink)
View 2000GTS's Photo Gallery
Do not keep driving the car....the brakes may lock up eventually!....did you replace the cylinder? Was the same problem occuring before you changed the brakes?
2000GTS is offline   Reply With Quote
Old 10-17-2004, 03:26 PM   #3 (permalink)
Yeah, I replaced both cylinders.
Old 10-17-2004, 11:37 PM   #4 (permalink)
but was this the problem that caused you to replace the brakes?? or was it just time to change them?
Old 10-18-2004, 10:12 AM   #5 (permalink)
It was just time to change them. I got them painted red so it'll look pretty cool when I get my custom wheels. They really did need to get replaced, though.
Old 10-18-2004, 11:25 AM   #6 (permalink)
are you sure their the right brakes and you put them on the right way? a lot of times with brakes its something simple cause theres not much there lol
Old 10-18-2004, 12:07 PM   #7 (permalink)
View canadiancelica's Photo Gallery
Is your handbrake tight ? You may want to slacken that off a bit from the handle adjustment. Other wise take it to a gargae and let them have a look, they have more experience with drums than most of us anyways, they do them on a daily basis, can't cost much for them to diagnose a problem.
John
canadiancelica is offline   Reply With Quote
Old 10-18-2004, 10:43 PM   #8 (permalink)
takin it to a garage might not be a bad idea especially since it happened after you were changing the brakes....let me know how things turn out...
