was the MIL flashing or just constantly lit?
quick and easy multiple misfire basic checks: charging voltage, manifold vac., fuel pressure(including regulator check), injector, and check plugs especially gap, belt tension, and visual on coil connectors, sensor connectors and all vac. lines. If all those check out ok, you move on to the next more involved checks. And since you have a scanner, view the freeze frame and start the car and view data. look for abnormal sensor signal voltage and long term fuel trim. shouldn't really clear codes unless you've done that.
