77 2.0L points gap? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2004, 01:28 PM   #1 (permalink)
View moron15's Photo Gallery
77 2.0L points gap?
I have a 1977 Toyota Celica 2.0L auto in the shop and I need the points gap and dwell setting please. Thanks
moron15 is offline   Reply With Quote
Old 10-27-2004, 02:02 PM   #2 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
First of all if you have the original motor then you don't have a 2.0L you have a 20R which is a 2.2L. Secondly you should consider switching to an electronic distributor so you don't have points. You can get these distributors on any R motor on the 78-95 motors. The point gap though should be set to .017" a good trick is to take a matchbook and use the top flap as your gap it is about .017"
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
