Oil Leak Help!! 94 Celica
My 1994 Celica ST started leaking quite a bit of oil recently, I have been under the car numerous times but it still is not clear where it is coming from, it is running down the oil pan, it is also running down the passenger side control arm(or whatever that part is that connects to the tire) the oil is spraying almost all the way down the underside of the passenger side of the car, their are large accumulations of oil splatter as far back as 2-3 feet from the engine, it is getting on the inner portion of the front wheel and i have been getting some light oil spots on the side of my car also. Could this even be an oil pan leak? i just though that because the oil is all over the pan but it is also all over that general area, it must spray the most when the car is moving as the oil splatter and amounts under the passenger cabin is ridiculous, any ideas? the car runs alright though and is losing less then a quart a week, so far at least. Please help with ideas, i was going to do the work myself but see how difficult the oil pan would be, plus i do not even know what else it could be, what else can leak like this in that area? Thanks
