1991 Celica Automatic Climate Control - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2004, 07:32 PM   #1 (permalink)
View ea8631's Photo Gallery
Just want to ask, beside the climate control switch and the temperature sensor, what other parts I need to convert a manual climate control to an automatic climate control?
83 Corolla s/w
01 Prius
ea8631 is offline   Reply With Quote
Old 11-03-2004, 07:41 PM   #2 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
You would need a whole different hvac box and under dash wiring harness. Because your original system uses cables to control the bypass doors, whereas the electronic system uses electronic actuators to open and close those doors.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 11-03-2004, 07:47 PM   #3 (permalink)
but isn't it already use the electronic system? since all of my hvac function is operate by push button type instead if the slide type?
83 Corolla s/w
01 Prius
Old 11-03-2004, 07:56 PM   #4 (permalink)
Not so Noob now!
es250nut's Avatar
I thought you said, you were converting from the manual Climate control to automatic? Or are you attempting to change out an electronic climate control system to one that controls the tempature more precisely?
Old 11-03-2004, 08:17 PM   #5 (permalink)
well..my airconditioning is an electronic type.....but can't set the temperature. And right now I want to convert my air conditioning so that I can set a temperature and let it run. I know there is an option on the same year of my celica, but my celica didn't come with it.
83 Corolla s/w
01 Prius
Old 11-04-2004, 09:01 AM   #6 (permalink)
GT-i Crew
lcarocha's Avatar
View lcarocha's Photo Gallery
Auto-climate, it came on the GT-S.
You will need a whole bunch of sensors (external temp, sun lux sensor, internal temp sensor) besides that the hvac box is different and I THINK (thus not sure) the evap has something extra.
Luis C.
92 Celica GT-i (ST182)
2nd Gen 3S-GE
Caracas, Venezuela
http://www.cardomain.com/id/luis_c
lcarocha is offline   Reply With Quote
