I was thinking of doing a swap into a 1994 Gts Celica and was wondering what you guys think the better motor is to swap in.
I dont want to go turbo because that will get too expensive too fast.
Right now the car has a blown 5sfe in it. I was just thinking would it be better to swap in another 5sfe or go for a JDM 3sge.
I know all of the engine mounts will line up but I am just wondering if it is worth the extra effort to swap motors for a 3sge.
There are many options... but it all depends on what you want to do... I would reccomend turboing the 5SFE because it'll pay off in the long run and is the cheapest route. It's much cheaper than a complete swap BTW. Swaps can nickle and dime you to death. Turbocharging a 5SFE can make enough power to be competitive with 3SGTEs... but it has its drawbacks.
Other options... I wouldn't go with a 2nd gen 3SGE (160hp)... I would go with the 3rd. It's map sensored, has a much better valvetrain set-up, higher compression, better stock camshafts, etc. It's a very good platform to start from, and it's actually probably a little easier because wiring up a MAP sensor is easier than an AFM. The BEAMS is even better, but is almost 2 times as difficult as far as wiring is concerned. The only problem... you can do a 3SGTE for about the same amount of money and have a motor with much higher potential. I personally build n/a motors and would go with the 3SGE... but a stock 3SGE doesn't feel a whole lot faster than a 5SFE...
__________________ It's ok to be naked, girl... I'm an Artist!
I was thinking of going the N/A higher compression route but I can get the second gen 3sge motor for cheap and with bolt ons I should run around 170-175 which would put down some good times.
I have never done it for the money.......except for that one time
Originally posted by Kwanza There are many options... but it all depends on what you want to do... I would reccomend turboing the 5SFE because it'll pay off in the long run and is the cheapest route. It's much cheaper than a complete swap BTW. Swaps can nickle and dime you to death. Turbocharging a 5SFE can make enough power to be competitive with 3SGTEs... but it has its drawbacks.
Unless you did a full bottom end rebuild, I think this would be a bad idea. Every turbo'd 5SFE I've seen so far has either snapped a rod or spun a bearing. I'm thinking with new bearings and rod hardware, it would be much more reliable. A 3SGTE head on a 5SFE bottom end would be worth looking into, but you'd need custom pistons to bump up compression, same with a 5SGE.
Originally posted by Deep Unless you did a full bottom end rebuild, I think this would be a bad idea. Every turbo'd 5SFE I've seen so far has either snapped a rod or spun a bearing. I'm thinking with new bearings and rod hardware, it would be much more reliable. A 3SGTE head on a 5SFE bottom end would be worth looking into, but you'd need custom pistons to bump up compression, same with a 5SGE.
It all depends on tuning when it comes to custom turbo kits. Granted, the bottom-end isn't all that, but it can handle mild boost (6-8 psi)... If shortcuts are taken (almost always) or if people get careless and up the boost... then yeah... boom. IMO, a safe reliable turbo set-up can be done.
As for a 5SGE... it's not a great idea either... To elaborate, the 5S block is an oversquared stroker design... so mating up a 3SG head wouldn't be very benefical. The reason is the 5S block doesn't rev very well, so it can't fully utilize the 3SG head's power making ability, which requires a fair amount of revving. I'd just go with the 3SGE if that were the case. Just can't have the best of both worlds n/a with such small displacment motors.
