Hard Starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2004, 08:29 PM   #1 (permalink)
speedyts49's Avatar
View speedyts49's Photo Gallery
Hard Starting
I had the oil changed, put in a new battery, air filter, and had the injectors cleaned by Jiffy lube.
I was hoping the injector purge might help with the starting problem.
It does start but I have to depress the pedal and crank it to get it to fire. It runs great and passed smog so I figure the fuel filter is ruled out. Still waiting on the factory service manual but could use some thoughts on what to look for.
'08 Super White Corolla S
'96 Tacoma 5 speed 2.4
'03 Kawaski ZRX 1200
speedyts49 is offline   Reply With Quote
Old 11-27-2004, 10:03 PM   #2 (permalink)
View boosted gt's Photo Gallery
try cycling the key 3 or 4 times before cranking. it if fires right up then its probably a clogged fuel filter or weak fuel pump
84 AE86 corolla SR-5 (sold)
89 toyota corolla sedan auto 217k (sold for $250 )
90 celica st auto 216k and counting
87 merkur XR4TI only 100k cause it never runs
00 crown vic P71 police interceptor 162k
boosted gt is offline   Reply With Quote
Old 11-27-2004, 10:50 PM   #3 (permalink)
speedyts49's Avatar
Ok I just tryed what you suggested and it did fire right up. I'll check into the two things you have mentioned starting with the cheapest first.
Old 11-27-2004, 11:51 PM   #4 (permalink)
View verybad's Photo Gallery
Unfortunately, an "Injector Purge at Jiffy Lube" doesn't check for leaky injectors that could be your problem. Sometimes, that method just forces crud into the business end of the injector.
Best if luck,
Gordon
WitchHunter Performance
Fuel Injector Cleaning & Flow testing service
verybad is offline   Reply With Quote
Old 11-29-2004, 11:04 AM   #5 (permalink)
View GeneralBenson's Photo Gallery
what do you mean, cycling the key, on?off, but not turn the engine? how does that tell whether it's the pump or filter. that;s interesting.
GeneralBenson is offline   Reply With Quote
Old 11-29-2004, 12:03 PM   #6 (permalink)
i mean just turn it to on but not crank. most efi cars when the key is turned to the on position it turns the pump on for a few seconds so if you do that a few times it will build fuel pressure without cranking the engine.
Old 11-29-2004, 06:16 PM   #7 (permalink)
speedyts49's Avatar
Weird, It now starts when cold without depressing the pedal but once warmed up it needs a quick pedal pump.
