to change the oil pan gasket, unbolt all the 10 mm bolts all the way around, to remove it. once you have it off clean all the reamining gasket (sealent) off of the bottom of the block and the oil pan. then use your black silicone sealant (toyota doesnt use cork gasket on oil pans, they leak too often) and run a good thick bead around the edge of the oil pan (the part that contacts the block), then use your finger to smear it around to make sure that there will be sealant all along the whole edge of the pan. you might want to wear gloves as this sealant is very messy, and very hard to get off of skin. then bolt it back on fill the motor with oil and yorue ready to go. might as well chage youre filter while your at it, being as you have to drain the oil out.
