rear wiper resevior on '90 GT-S - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2004, 06:33 PM   #16 (permalink)
View slvrblt's Photo Gallery
if the washer pump is broke i would get it from toyota, i had to repace mine in my 90 gt and the one i ordered from advance auto only had one outlet. Also if the rear washer had not been used in a while the check valves in the line may be stuck closed as mine were, i fixed this by blowing air from an air compressor into the line to free the check valves. hope this helps.
slvrblt is offline   Reply With Quote
Old 12-15-2004, 03:03 PM   #17 (permalink)
View dafunk_80's Photo Gallery
I have the exact same problem,, no washer fluid to the rear ! (90 GTS) Anyway, I looked for the rear hose, but I cant even figure out where the washer fluid even comes out at the rear. I kinda gave up on it, but hey if you can figure out where the washer fluid comes out on the rear, so I can check where the hose is,, and if its clogged or even connected! Does anyone know where the hose runs? Bottom of the car or on the inside?
1990 Celica GTS 2.2L 5S-FE
dafunk_80 is offline   Reply With Quote
Old 12-15-2004, 03:07 PM   #18 (permalink)
Gameroom cash: $147537
Passenger side under door sill. Fluid come out from the black plastic nozzle on top and center of hatch.
Old 12-19-2004, 11:14 AM   #19 (permalink)
View GTSR5Corolla's Photo Gallery
Bah.. this car is my baby so it's like painful for me to think about having to rip shit apart or even jack it up and pull a tire and work on it.. lol.
GTSR5Corolla is offline   Reply With Quote
Old 12-19-2004, 06:16 PM   #20 (permalink)
View braddog0128's Photo Gallery
my old all-trac was that way too, just a lil squirt...
braddog0128 is offline   Reply With Quote
Old 08-12-2005, 02:31 AM   #21 (permalink)
View yooperjust's Photo Gallery
Neither my front nor rear fluid was squirting out, so, I wired up the motor to the battery...it makes a lil noise, but, not a whole lot. Now, when hooked up, I turned the lever to squirt fluid out and nothing happened....not a sound from the motor. Does any know or know someone that knows the wiring decent enough to give me suggestions on how to diagnose this problem?? I don't wanna take the car in to a mechanic, but, there are several little wiring-related problems I am encountering...of which i plan to conquer one at a time.
Thanks,
-Justin
yooperjust is offline   Reply With Quote
