Car suddenly not starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2004, 02:42 PM   #1 (permalink)
View 86celica's Photo Gallery
Unhappy Car suddenly not starting
Last night i started my car ( - 20, started fine), drove to my friends, parked in the heated parkade, came out two hours later and the car won't start. It doesn't turn over and it doesn't make any clicking noises. The lights are bright and the stereo and accessories all run. I am thinking that it is either the neutral safety switch or the starter. Any opinions?
86celica is offline   Reply With Quote
Old 12-23-2004, 02:47 PM   #2 (permalink)
Gameroom cash: $147537
Looks like loss wire somewhere. Try put it in P or N and see if it start.
Old 12-23-2004, 02:49 PM   #3 (permalink)
It's a standard.
Also, i am going to try to push start it later. Anything i should be looking for?
Old 12-23-2004, 03:14 PM   #4 (permalink)
Maybe your clutch switch is lose or stuck.
Old 12-23-2004, 04:48 PM   #5 (permalink)
Sarstan237's Avatar
View Sarstan237's Photo Gallery
I'm personally going to say the starter or ignition switch. We had the same problem with our '82 Celica and my father ever so gracefuly hotwired the car. He ran a line from the negative terminal of the battery to the driver and then another wire from the starter up to the driver. When the ignition is turned, it won't start, but by touching the wires (only with the ignition switch turned, key in) it'll start up.
Sarstan237 is offline   Reply With Quote
Old 12-24-2004, 12:30 PM   #6 (permalink)
Okay, i went back and it started right up! Now i'm confused, and wondering when it will happen again.
Is it possible that it had something to do with the weather? Before it died, it was minus 20 degrees celcius outside, then i parked it in a heated garage (about 20 degrees ABOVE zero). Could a drastic temperature change like that affect it?
Old 12-24-2004, 04:20 PM   #7 (permalink)
MadDawg's Avatar
View MadDawg's Photo Gallery
Your car must have gotten used to Minus degree weather
MadDawg is offline   Reply With Quote
Old 12-24-2004, 04:32 PM   #8 (permalink)
Boooost
turbo_GT's Avatar
View turbo_GT's Photo Gallery
it's probably your starter..had the same problem before..just knocked the starter..and she started fine again..
Your signature is in violation of rule #4.
http://www.toyotanation.com/forum/t20118.html
turbo_GT is offline   Reply With Quote
