91 Celica GT ..Needs Advice - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2004, 07:06 PM   #1 (permalink)
View celica91gt's Photo Gallery
I just bought a '91 Celica GT Sport Coupe 2D from a friend and found out that the nightmare has just begun. I brought it to a mechanic and was told that I need at least 1000 dollars to spend on repairing the car. I paid 1000 dollars for the car alone and am not sure if I should go ahead and sell the car or repair it. I need to fix these:
1) Radiator (leaking, need to be replaced)
2) Timing belt
3) Spark Plugs
4) Left Axle
Please leave me some advice. What parts can be replace by myself? I'm really out of money now. Trying to save some labor charge here.
Thanks
Dave
celica91gt is offline   Reply With Quote
Old 12-28-2004, 07:34 PM   #2 (permalink)
View dafunk_80's Photo Gallery
Sparkplugs and radiator should not be too complex if you follow along in a repair manual,, but this all depends on how experienced you are or how comfortable ur.. But thats too bad the timing belt is gone.. that's gonna be expensive to fix.. they'll ask you if you wanna replace your water pump at the same time since it can be done at the same time.. Up to you if you're willing to pay the $$ !
1990 Celica GTS 2.2L 5S-FE
dafunk_80 is offline   Reply With Quote
Old 12-28-2004, 08:31 PM   #3 (permalink)
Angry
that's the bad thing about it. The timing belt costs about 300 dollars. Huh, don't know if i should fix that. Anyway, what is the most important thing? I don't think i can afford to fix them all at a time. Will go one by one.
Which one should i fix first? Radiator? Timing Belt?
And, how much is an air filter gonna cost?
Thanks.
Old 12-28-2004, 08:39 PM   #4 (permalink)
Always Bored
View hachi-rocu's Photo Gallery
spark plugs are cheap and you could do them yourself
air filter shouldnt be too expensive either
you need both the rad and the timing belt done to drive. If the belt breaks then you will need a new motor.
I have never done it for the money.......except for that one time
hachi-rocu is offline   Reply With Quote
Old 12-28-2004, 09:43 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
the s motors wont bend the valves, if the belt breaks the motor will just stop, do the radiator first along with the plugs, you can probably do these 2 things yourself
Old 12-29-2004, 09:50 AM   #6 (permalink)
Gameroom cash: $147537
Any car will need those part sooner or later. You got a pretty goo d deal for 1G. Fix it up and keep it.
If you can afford to tow it home, you don't need to fix the timing belt now. Pull the top belt cover off to see if the belt is cracked or not. If it looks good, then you can wait.
Rad is less then $200. Do a flush before you remove the old one. Fix the rad first. If you overheat the engine, you're looking into more expensive repair.
