Need advice on the GT-S - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2005, 03:54 PM   #1 (permalink)
View naruto fanboy's Photo Gallery
i just got a 2001 celica GT-S and iam wondring what kind of rims do u recomend , iam a newb so i dont realy know the size or nothing
naruto fanboy is offline   Reply With Quote
Old 01-03-2005, 04:23 PM   #2 (permalink)
View Deep's Photo Gallery
Because of the lack of torque I would probably stick with some lightweight 17's. A good rule of thumb is 1lb for every inch in diameter, which means wheels that weigh around 17lbs or less would be ideal. Lighter wheels are considerably more expensive though, if you don't care much about performance, then you can go heavier.
The bolt pattern for the Celica is 5x100 and the stock offset is 38, try to stay close to the stock offset to avoid fitment problems.
Use this: http://www.1010tires.com/TireSizeCalculator.asp to find the closest overall diameter to your stock wheels. I *think* stock size for a GTS is 205/55R16, in which case 205/50R17 seems pretty close. 215/45R17 would also be pretty close, but the tire would be slightly wider, giving a slightly more aggressive look and a little more traction in ideal conditions.
Deep is offline   Reply With Quote
Old 01-03-2005, 04:48 PM   #3 (permalink)
Serge's Avatar
View Serge's Photo Gallery
Just what deep said.
the gt-s has no low end power, so watch out for heavy rims. if youre selling ur 16's let me know i want to move up from my stock 15's
Serge is offline   Reply With Quote
